04 5.3??'s
04 5.3??'s
I have an 04 5.3 out of a gmc truck that I'm putting in my 65 chevy truck and I am looking for a cam. Recomend me something that will work with what I have please. I'm looking for a lope at idle but not interested in those thumper cams!!! I just want it to sound aggressive at idle an have some go also...
1965 chevy truck, 3.73 rear gear, 26" tire, 700r4 trans 24-2800 stall, 4000 lbs! I have a demon 650 carb now that I am keeping as I have a really good carb guy! Going with the edelbrock duel plane intake an 6ls box.
In-Zane Moderator
How aggressive you want? That converter is small for anything that is really a ground shaking cam. The hot cam ground on a 110 LSA would be decent. The edelbrock 2215 is right where you want to be weight wise and only need the cam. Will use the stock springs as well. Upgrading to LS6 springs will prevent valve float. The hot cam can use them as well.
I can get a looser convertor that's not a big deal. I plan on running some beehive springs also so lift shouldn't be a problem. I want it to run as well as it sounds but I want pretty aggressive sounding but still drivable... An will support future upgrades!
In-Zane Moderator
If you will go with a 3500 converter, you should be in good shape with this:
http://www.tickperformance.com/tick-...1-ls6-engines/
It is kind of on the edge of what you are looking for, but will respond to ported heads in the future and will have the sound you are asking for. Should still bring TQ in quick and no be lazy.
Tick grinds them as you can see. For the best results, dont be scared to give them a shout and have a custom grind made to your likings that is one off and exactly what you are looking for. Martin is the guy to talk to.
Wow 3500 in a street truck @4000 lbs sounds alittle high. I'm worried about tranny temps when crushing with a stall that high. This truck will be a driver! It will still be a lockup converter but still sounds aweful high.
Ok I trust ya! I'm ls stupid... Just started tearing the topend off and broke 4 bolts on manifolds. Two out of the hole and two in so now I get to play with that.. Thank go I have done this 1000 times at work!
