Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
New to Carbs Need input please
Old 06-22-2013, 07:53 PM
62c10's Avatar
Default New to Carbs Need input please
Hey guys Im building a 62 c10 street truck just for cruisin and what not. Im not trying to go super fast and probably wont ever go to the track. Ive got an 03 express that Im pulling the motor out of (and what ever else I may need) The van has been mine since it had 15 miles on it and now it has 365k I know shes tired but she still runs great. what Im wondering is what intake and carb and ignition box to buy? I wont be doing anything to this motor performance wise. I will probably get another 5.3 down the road and do some mild work to it. Probably cam valve springs some minor head work or what ever. And please be aware Im a carb idiot. So the eaiser to setup the better. Thanks guys Ive been snooping around for a while but now its time to start on this thing.
Old 06-22-2013, 08:17 PM
Doug G's Avatar
On just a cruiser 5.3, I think a 650 vacuum secondary will be fine and IF you plan to hammer it any a 750 VS would be better.
I think thats a 24 tooth wheel motor which would be a 6010 MSD box.
Also for the streeter theme...a dual plane intake.
Get with one of the sponsors and they'll hook you up....MikeF at S-K-speed is who I went with and have nothing but good things to say
Old 06-22-2013, 08:22 PM
In-Zane Moderator
ZONES89RS's Avatar
Everything above is spot on. You may be happy and leave it in and just throw a small cam in later.
Old 06-22-2013, 08:29 PM
62c10's Avatar
I think a 750 would be cool I dont mind the ability to get in it now and then. Any suggestions on what carb? And what dual plane intake?
Old 06-22-2013, 09:04 PM
windmill's Avatar
these guys are right on,, these motors r so strange,,, I went from a rpm to a vic jr I run almost same jets but had to go so much bigger in squirters is not real but it leaves hard and no bog
was running like with rpm 35 and 37
vic now 53 and 63 ,,,lol but it leaves hard and runs
Old 06-22-2013, 09:06 PM
62c10's Avatar
No idea what that means. Im assuming fuel jetting?
Old 06-22-2013, 10:16 PM
windmill's Avatar
lol,, no that's the squirters in a holley carb
Old 06-22-2013, 10:22 PM
62c10's Avatar
Sorry. Like I said Im a carb idiot.
Old 06-22-2013, 11:30 PM
In-Zane Moderator
ZONES89RS's Avatar
A regular run of the mill 750 vacuum secondary off eBay or Craig's list will work fine. Just rebuild it of needed.
Old 06-23-2013, 12:31 AM
62c10's Avatar
Any preferred brand? Im sure thats a debatible question.
Old 06-23-2013, 02:00 AM
62c10's Avatar
So I think I came up with a parts list. Let me know what you guys think.
Carb.
http://m.summitracing.com/parts/hly-0-3310sa
A Performer rpm intake manifold
and the msd 6010 ingnition box.
Would I be able to add like a 100 shot of nos easily to this setup down the road?
Old 06-23-2013, 06:19 AM
In-Zane Moderator
ZONES89RS's Avatar
Spot on!
The ignition controller will allow you to pull timing when the nitrous is activated. It is a very cost effective system.
Old 06-23-2013, 06:53 AM
Doug G's Avatar
And do NOT use the pills that comes with it.....consensus is, over timed.
Old 06-23-2013, 01:10 PM
62c10's Avatar
Dont use the pills with nos or at all?
Old 06-23-2013, 02:09 PM
Doug G's Avatar
at all......one guy found out the MAP timing was being added and didn't even have it hooked up.
Write your own curve
Old 06-23-2013, 06:12 PM
62c10's Avatar
Hmmm... is there a place to get base line timing curves from? And does it require any additional hardware to program? (aside from a laptop)
Old 06-24-2013, 02:09 AM
In-Zane Moderator
ZONES89RS's Avatar
Comes with the software and a base line is 16* at zero and all in to 34 by 2500 rpm across the board and dial in from there.
Old 06-24-2013, 10:08 PM
62c10's Avatar
Sounds pretty easy.
Old 06-24-2013, 11:01 PM
In-Zane Moderator
ZONES89RS's Avatar
It is. You will lol once you play with the software.
Old 06-24-2013, 11:10 PM
62c10's Avatar
Sweet. Now that I've got this all sorted out time to decide on a transmission... Easy and cheaper th400 or 4l80e... I have a 4l60e already but I hate them. Been through to many.
Quick Reply: New to Carbs Need input please
