Holley LS3/L92 Dual Plane
Thanks for your thoughts. I agree that this could end up with little or no benefit. Forgot to mention the 4.10 gears and my set-up spins to 7000+ rpm without a wimper.I think the new found low end torque will be nice on the street, but could be a problem at the track. I run 1.60 Ft times now (not great) with my GMPP single plane and current set-up. I am still on the fence and if the price comes in @$259.00 I may give it s try anyway. Only one way to find out
Bruce
LOL at snook. O.B. couldn't have said it better himself.
Can't wait to see some other guys results with the Chinese intake. At 400.00+ for a start-up cost. I think someone overestimated the market for crappy finished, extremely tall Chinese intakes with dominator bases.
Look for one soon in a Hot Rod or Car Craft magazine.
I want to try a victor on Freddie. And the Datsun in my avatar is getting a LY6. I may go with the dual plane if I don't go EFI. Square ports and short is the order. I don't want a hood scoop.
Either way neither are available.
http://www.superchevy.com/hotnews/13..._new_ls_parts/
I might go this route. Ill keep mine and try both and see if theres a difference at the track then keep the best one. My power was showing it was starting to peak at about 6900 rpm but they couldnt go higher, the tires were vibrating on the dyno too much. Will this handle 7k+ rpm?
#32
#33
Mine is a stock cube lq9. Stock ls3 heads with a untouched victor jr. The cam is larger (234/250, .621/.629 112+4) but my converter is lowish (3200-3400) I made good flat torque on the dyno from about 3200 to 6400 so maybe this single plane would be ok. It started to peak at 6900 but I run it out to 7100 with my msd set at 7200. I expected this cam to pull higher like 7400 but something is holding it back. Or im just expectin too much from all these factory parts haha. Im excited to get the fast and fire it up. Im puttin it right on and firing it up in the cold for a test right when I get it lol. I got a 8 point cage goin in in 2 weeks so it will be gone for a weekend... hopefully my w2's show up soon so I can get these parts
#34
#35
Old School Heavy
The hand held that comes with the Fast unit is very informative ,once you figure out what its saying. According to my display, I am at max fuel consumption at 6700rpms, so my 7K shift point is too high for best power. Not to mention, it only drops back to 5200 on the 1-2 shift. What all that means is, the fast has taught me , my shift points need to be about 300rpms lower. That will keep me from loosing acceleration , reving past my max HP (max fuel consumption) and should drop me back into the meat of my TQ band on the shift. Lots of power in my combo to be had in the high 4000rpm range. Sio shift at 6700, drop back to 4800-4900 in second and let the TQ pull me through.
#36
When Tim speced the cam out, we talked about shift points and peaks etc..I asked where he thought the cam would peak out and he said it could be all over at 6k, but that the heads may carry the cam higher. My next question was, so shift at 6500 to get into the next gear at a good RPM. His comment was, that with the tight LSA and the mid range TQ it should make, there would be no reason to push the RPMs out, because it would fall right into the meat of the TQ curve without pushing the rpms up higher. That is what the car feels like. On my 2nd pass on my last trip to the track, I shifted into 3rd at 6500 vrs 7000 on all the other gear changes on both passes. There was a definite surge forward on that gear change that didn't happen on the others. The pass was quicker also, but I had done a little better on getting the car off the line on that pass too. Its worth a try when I go back as Im sure that dinky cam isn't still making power at 7K. I guess we will see,
#37
Old School Heavy
It will really depend on where your rear wheel peak power is actually at, and how quickly your power curve drops off after peak. If your HP drops off a cliff just after peak power, then a quick shift will be beneficial. If your power carrries past the peak nicely, then you will go faster by shifting 200 to 300 RPM or more past the peak.
It is all about average horsepower. Your car drops from 7000 to 5200 on the shifts. That means that you want the highest average horsepower you can get in that 1800 RPM window. For an exercise, you could take a dyno sheet and draw a horizontal line under the power peak that had an 1800 Rpm range. Your goal is to get as much area in that contained area as possible for that 1800 RPM range. You will quickly notice that how broad your power curve is and how quickly your power drops off after peak will determine where that horizontal line will intersect your horsepower curve.
Ignore the whole torque thing. It is not an effective number compared to HP under the curve for determining shift points. It is a very useful number for designing a torque converter, but not for shift points.
#38
Now back to the subject at hand. Sorry about the jack, 364.
#39
Thanks for the pointers! I will end up using the victor jr right away this year nd see how it acts. But for a whole 250 extra I can try the holley. I will postthe results this summer for sure!
#40
I just ordered the 300-130 direct from Holley yesterday, got the shipping notice Today . I will get it on Monday. Then I will port it and polish it inside and out. It's winter time got nothing much better to do , so I might as well make it purty.
Also ordered the MSD bok and a few other parts from Mike at SKSpeed, got the notice that it was packed and shipped within a few Hours. Impressive these Guys don't **** around , and the price was great ! Stan
