Neanderthal Carb Guy BS Thread
#562
Bent pinion yoke
Twisted trans slip yoke
Pinion angle.
Sometimes you can jack the rear of the car up and put the axle tubes on jack stands. Start Adding weight to the drive shaft with hose clamps in different clock positions until you reduce or eliminate the vibration.
Also, check the runout.
Trust me. It's shiny.
#566
In-Zane Moderator
Literally picked the DS up from fresh balance with new U joints yesterday.
Been doing a ton of digging. One guy said his vibration went away at -0.5 pinion angle and one guy said he had to go -4.5.
I'm at -2.5, and it was at -1.0, so I'll throw more at it and keep messing with it. Really pissing me off.
#567
#577
Took the car up on the highway the other night and remembered how nice my 3.42's were. I decided to re gear my
New rear again before I even put it in. Took the 3.73's out and put a lightened richmond 3.55 gear set in. Waiting for my trick chassis control arms to show up and she should be in the car.
