AN fittings for transmission lines
Ok so i want to run -6 braided hose for my trans lines, i found the fittings for the 4l80e but cant find specs on the fittings i need on the radiator, radiator is a stock unit for a ls1 camaro. Can someone please help me figure this out thanks
I believe, and someone correct me if im wrong, that the stock fitting in the radiator is 5/8 inverted flare.
these should work.
http://www.summitracing.com/parts/rus-640380/overview/
these should work.
