msd 6ls or distributor
im in the final stages of ordering parts for my 6.0, and wanted some info on keeping the coil packs vs going distributor. reason im on the fence is:
1. my coil packs are shot, ill have to buy all 8 new
2. ill have to buy a new laptop to tweak the timing
so whats yalls opinion
street with some strip, from what ive got on paper, I can keep the coil packs use a 6ls, wiring harness, and a new laptop thanks to the kids and ill be 1500 or so in it with all new parts. or distributor and have roughly the same amount tied up give or take a few.
Ive sen where to run the distributor you have to have a stewart brand water pump, but also was told you can use a factory water pump and use spacers to get everything lined up, that true?
I would stick to a 6LS.
With a distributor you can run spacers for the water pump but have to fab up the belt drive for the water pump and alternator.
It is a fair chunk more money when you add up the front cover a distributor and a programable ignition box and coil. A dampener that fits and pulley system etc. it snowballs fast.
Distributors are great if you have the need to use the functions in ignitions like a power grid. This will be more for strip only cars that need the tuning capability
distributor been great for me as a strip car. zero issues with timing and spark, very simple, set and forget. by the time i sold the manifold and injectors, coils, it wasn't that much more.
I'm planning on running the Summit ET series next year and found out the 6LS box isn't on the NHRA approved product list. I've sent an email to the div4 office but haven't heard anything back. It would suck to go through the expense of becoming an NHRA member only to find out I can't compete.
That said, I'm loving my 6LS (6012) box. Way better than messing with a distributor.
Still no word, but it's not looking good. I haven't been able to find any information on the web that says I will be able to compete with my 6012 box, and if I must swap to a distributor I'm screwed because I have no room for one.
Btw, this is the NHRA Approved Product list I've been talking about. It's current as of 11/4/14, even though the ignition box section hasn't been updated since 2012.
http://www.nhra.com/userfiles/file/NHRAAcceptedProducts.pdf
On a side note, I found something interesting while searching the web. It seems that MSD isn't the only game in town anymore. Daytona Sensors has released a box to compete with the 6010/6012 called the Smartspark LS (p# 119001). They're calling it an upgrade to the 6LS and it looks to be able to do anything the MSD box can do and more (like individual cylinder tuning).
Also, stang_kllr, this box has 3 programmable inputs for retard (each with 20 degree max retard). I wonder if they could be stacked to give the retard you need on each stage. Might be worth looking into.
Link
http://www.daytona-sensors.com/SmartSpark.html
Instructions
http://www.daytona-sensors.com/download/SmartSpark_LS_Instructions.pdf
Link
Instructions
Link
Instructions
http://www.daytona-sensors.com/downl...structions.pdf
Link
Instructions
Another alternative to the MSD 6010/6012 is the MegaJolt Lite Jr DIY Standalone EDIS-based ignition.
http://www.autosportlabs.net/MegaJol..._Users_Welcome!
The original Megajolt was developed in parallel with Megasquirt about 20 years ago. Because it is Ford EDIS-based, it must be triggered by a OEM crank wheel and sensor. The EDIS can fire GM 2.2L dual coil packs (wasted spark mode), in addition to Ford coils.
The MegaJolt Lite Jr, like MegaSquirt, has to be user programmed and seems very capable. It can be adapted to 4, 6 or 8 cylinder engines. It is compatible with carb(s) or EFI. It can also be customized for nitrous, turbochargers or superchargers. I am personally considering this for my 6.0L street Vega. It also has a base price under $200 and the supporting parts are readily available online, and in auto parts stores and salvage yards.
Old School Heavy
Link
Instructions
Link
Instructions
If I am reading their website correctly at over $500 for the Smartspark box + harness + USB interface it is considerably more expensive than the MSD box.
Still less than the FAST controller at over $600
