Carb'd street/strip - what oil you guys use?
As per title, let's hear what brand and grade of engine oil everyone is running.
Synthetic, Mineral, Blend?
5w30, 10w40, 15w50?
I have heard mixed opinions and am leaning towards a full synthetic race oil, but yet to decide if it is worth the extra funds over a more conventional oil.
5w30, 10w40, 15w50?
Thanks for the responses all, about where I figured many would be with the variation of mainly lighter weight oils. I think I will go with the full synthetic with there being so many more to choose from over mineral and blends. I guess eventually synthetic may be all that is available in the future.
Not going to say I agree 100% when many of us here will see shift points (some 7000+ rpm) that the factory never intended the engines purpose for such conditions.
Old School Heavy
Don't ever use oil if the seal is broken. Listen to this: Just put a new timing chain and chain damper on my car. Because I had the engine open, I decided to change the oil. I bought the oil from Walmart. When I took the car out after the change, I had lower upper RPM oil pressure. The idle oil pressure was the same 30-35 pounds it had always been, but as the RPM rose, the oil pressure barely came up.
Because I had the oil pump off to install the timing chain, all kinds of ideas were going through my head. I was thinking I was going to have to pull it all back apart to look for the problem. But, then I remembered the the seal was broken on the gallon of oil when I bought it. So, just to see, I put in new oil. Viola! Normal oil pressure.
So, somebody did something or made some kind of switch to that oil. Who knows what. But, if the seal is broken, the oil is going back next time fore sure.
10-40 Castrol Full Synthetic w/ a bottle of ZZDDP......no such things as cold starts with this oil......68 starts up like a 2014 off the showroom floor.....revs alot faster, and jus overall runs better than conventional oil w/ a great idle....engine has about 650 miles on it....
In-Zane Moderator
Heard of that stuff referred to as "scamsoil". Guess there are haters and sponsors.
Why the zzddp? That's for flat tappet motors.
And castrol is not a full synthetic so I wouldn't waste your cash and use Mobil 1.
