Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
How to run Stock electric G.M. fan setup ??
Old 12-07-2014, 09:47 AM
1973 STEP A SIDE's Avatar
Default How to run Stock electric G.M. fan setup ??
So we have are 5.3 motor swap done and are looking at fans . After checking into the after market it either very cheap or very expensive . So I start looking at a duel fan setup from RocKAuto G.M. fans are cheap when compare to good after market brands .
So my question is what is needed to run a duel electric G.M.fan on a carbed motor in a non computer application ?
Old 12-07-2014, 11:39 AM
keving502's Avatar
I bought a dual fan setup from a early 2000 camaro at a local Pull-A-Part for 28 bucks. Simple toggle switch ran thru a relay.
Old 12-07-2014, 11:58 AM
I would like it to run through a relay and not a manual switch and have it turn on and off at like 170* to 185* just need to know what G.M. parts to buy . Also would like to stay all G.M. if possible .
Old 12-08-2014, 07:51 AM
Can any one help me out with this ?
Old 12-13-2014, 05:32 PM
billymgb1000's Avatar
Hey 73 I would go on ebay and type in electric fans temp control, you should find something there. it probably wont be gm but it's only a temp switch. mine comes on at 180 off 170 there are even variable ones good luck brother
Bill G
Old 12-13-2014, 08:18 PM
76larkman's Avatar
LT1Swap.com has fan wiring info to run with relays.
Old 12-15-2014, 09:23 AM
N20zuki's Avatar
I tried to stay simple on my setup. I am running Dorman C5 Corvette replacement fans, And a Imperial fan controller with a temperature probe that slides between the radiator fins. Its advertised to come on at 185, and I have never seen my temp gauge get above 200 in Florida traffic. Its been like this for 2yrs and 8500 miles without any issues.
Old 12-17-2014, 08:47 PM
Thanks to all that chimed in but I bought A Flex a Lite duel fan set up with prob and temp adjust sensor .
Quick Reply: How to run Stock electric G.M. fan setup ??
