What total timing are you guys running on a 150shot?
What total timing are you guys running on a 150shot? Just curious I run 32 n/a and was gonna pull it back to 22 on a 150 shot wet kit and go from there.
Awesome. Gives me an idea where to start at and work up to and read my plugs. Streetknight2 what are the jets you are using on nitrous and fuel for that 150? I have got people telling me all kinds of different jet sizes for 150 which doesnt make since to me.
What kind of system do you have?
Well I have decided if i'm going to run a direct port fogger or a single plate. I know all I need is a plate but I like the fogger better for the future and a bigger shot. May run both plate with 100 off the line then kick out and fogger with 200 the rest. Engine is a 2010 Ly6 with nascar ls2 forged crank rods and pistons. Pistons are JE flat tops with valve reliefs. Ls3 heads milled 40 with .040 cometic headgaskets arp bolts. Cam is a 235/242 637/615 on 111. Compression ends up at 11.7:1 is what my friend came up with. Also im running a Holley Ultra carb, 3600 stall, th350. built 9" 3.50 gear and 26x10.5 et streets or 275 pro radials. Car is 2980.
I'm no help with a fogger, haven't used one since the 90's. I would have it professionally installed and flowed or at least flowed if it were me, then you'll have your tune ups. Steve Johnson or Monte Smith would be who I'd use on a fogger.
I've tested extensively with the NOS Big Shot Plate and and the Nitrous Outlet Stinger. I could help with those.
What are your thoughts on a stinger? I really am interested in one. If I did a fogger it'd be either induction solutions or Cold fusion. Leaning towards cold fusion on the fogger as I have several friends that use them.
I like the stinger so far but I haven't hit it with more than a 150. Just remember with whatever you choose, you get what you pay for
