Quick fuel 680 vs help !!!
Got every thing back together and fired it up . I am so rich at idle you cant stand it . Tore it down reset every thing and still way to rich . I started it for the first time with pill #1 . Today after going through the carb I changed to pill #6 and still to rich .
#1 Should I change the air bleed it has #70 in there now .
#2 Drill the butterfly's
I have been reading a lot about Quick Fuel on other forums and every one I read that had this kind of problem but no one seemed to follow through and fix the problem .
HELP !!!!
HELP !!!!
The build .
Quick Fuel HR-680-VS
Edelbrock Intake #71187 Performer RPM LS1 Duel Plane Manifold
MSD Ignition Controller#6010
As Cast PRC Stage 2.5 5.3L CNC Ported Heads Milled .017
GM 5.3L Multi-Layer Steel Head Gasket #28-12589226
MR45676 1 ¾” ceramic coated long tube headers 3" collectors
GM Gen III Cylinder Head Bolt Kit #28-12498545
GM ls2 Timing Chain # 12586482
Comp Cam ***** Thumpr 283THR7 High Performance Street/Strip
Melling 10296 Oil Pump
Moroso GM LS Valley Plate
GM LH8 Pan Kit #19212593
3" duels to stock location (behind rear tires) Flowmaster with H pipe .
HELP !!!!
HELP !!!!
does it not have idle mixture screws? I don't drill the blades to lean it up at idle.
throw the pills away and set a custom timing map. the pills keep the timing too low IMO
I recommend that you get a wideband to tune along with your vacuum gauge. before changing anything, work the idle mixture screws. if the idle mixture screws are hyper sensitive, and the off idle tip in goes super rich I would think you need smaller idle feed restrictors. don't change anything blind though.
