Help on the LQ4 build!!
So I picked up a 190K mile lq4 awhile back for $300, and it didn't have the fuel injection setup with it, so I decided to go the carb'd route since FI is too spendy and there's not many places to go get a tune on a fuel injected car where I'm at.
I got the victor jr intake and msd 6010 ignition system. I am still not sure which cam I want to go with, Can't decide between the Lingenfelter Gt2-3 or the Texas speed torquer v3. Anyone prefer one over the other? Also this will be a street car that will very seldom see track days.
Got the bores checked by a machine shop and they just need a hone to clean them up, crank is good just needs to be polished. Going to replace all the bearings, piston rings, might replace pistons and rods (I heard the rods were the weakest link in the LS6s).
This is my first LS build and was looking for some advice on the build- what to check, what to replace, etc.
Plans are to run NA for awhile with stock parts, and then go a supercharged route with eventual upgrades to heads, internals, etc.
Also, does anyone have a similar build with HP/TQ numbers? Thanks!
I also have an LQ4. I removed the 317 heads and installed stock 799 heads which raised my compression to about 10.1 I got a custom cam made for my application.
When you swap the cam get good lifters, pushrods, and at least do a trunion upgrade on your rocker arms if you keep the stock ones, they are another weak link.
I installed my LQ4 bone stock in my car, added headers, carb, and vic jr intake. It went 11.80's. Installed the custom cam the following year and its down to 11.23 so far.
Old School Heavy
If you could share more about the vehicle the engine is going in, it would be helpful.
What is the car?
Intended use?
Rear Gear?
Transmission?
If automatic, what stall converter?
What driving characteristics do you want?
How do you want it to idle? smooth? Muscle car? Hot Rod? etc.
What is the car?
Intended use?
Rear Gear?
Transmission?
What is the car?
Intended use?
Rear Gear?
Transmission?
What is the car?
Intended use?
Rear Gear?
Transmission?
