Fitech install goodbye carb.
Funny this thread just popped back up. My buddy with the FiTech just found out his fuel gauge is off....lol
Said he knew he was low, tried to make it to the gas station from where he was, left a light fairly hard, heard a pop, car cut off (no stumble), no re-start....call of shame to his wife to bring the gas can.....
I just installed a Mean Street throttle body fuel injection unit on my 87 Monte Carlo SS.I had an 08 6.2 with a 850 Quickfuel carb,thunder racing cam,GM open plenum intake,turbo 400,3600 stall,9" with 3:70 gears.Carb just got to be a pain instantly filling garage with fumes and I just got tired smelling of the fumes.I already have GrandNational tank,pump and sending unit.I installed a 255lph pump and ran a return from throttle body to a Y at my corvette regulator.3 wires to hook up and coolant sensor and o2 sensor.Few questions to answer on little dashboard computer and it was running.The best thing I've done to this car to make it a pleasure to drive
most people would treat their cards like a FI . Put it on and drive it. Most wouldn't go through the hassle to tune it. Throttlebody FI has its place. ( retrofits )
Doug, how long has he been running it and how does he like it? I'm considering buying one myself. I'm mainly interested because the same unit could work on any engine with a carbureted intake.
He's not the greatest tuner, and I can say I'm a little jealous of him being able to just reach in the window to turn the key and it fires right up.... regardless of temp outside.
Thank you. I've done some more reading of people's experiences and can't find anything really negative about the actual injection system. There's some complaints about the fuel side that are mostly heat related, but most complaints I've read about the injection unit has been due to user error / lack of knowledge in programming. Also a few were from very early units that had hiccups but the company took care of them.
My biggest concern is possible (probable) lack of support or replacement parts 5 years or more down the road when things naturally wear out.
This reply relates to all three of these posts in some way.
-We went Fitech after several GM EFI age related parts failures turned into constant troubleshooting. First swapped to carb, then Fitech.
-Fitech is NOT self tuning. It takes as much f'cking around w/ the tuner as it does mechanically swapping carb orifices to get it set even close...without ever getting to a correct setting.
-Recently sent Fitech a final request for help before pulling their unit, 15 months after purchase. Got no reply. Probably due to it being 3 months past warranty.
-Have run inot more than a handful of people of whom returned their Fitech EFI due to its' lack of performance.
For 1/4 WOT runs...it's probably tuneable. For any type of spirited on/off throttle driving w/ hard cornering, it's a POS.
If EFI is your choice, pay more & get something that works for every driving condition. Fitech isn't the answer.
Anywho, he's had it about a year. Not driven a lot, so maybe 500-1000 miles on it ?
No track time.
fitech update
Ive put a couple hundred miles on my Monte Carlo SS w/Fitech 800 HP Meanstreet.I personally have not had any issues wth mine at all.The car runs great,will burn the tires off from a 20 mph roll till you get out of throttle.Ive joined a couple groups on Facebook relating to Fitech and tuning of,changing parameters on controller.I've heard good and bad about the system,but I'm happy with mine.
#33
temp sending unit
I have it on the passenger side rear head coolant hole.I have my stock 305 temp. sending unit turned down to fit into front drivers side head.This goes to my stock gage and they are both pretty close to each other.
#35
My car has been in storage since Oct. of last year.Got it out at end of July charged battery up and it fired right up.Ihear all the stories of this is junk or it would'nt run right.I think alot of it has to do with installation.
#38
Running efi and msd6010
Hey man I currently have the same set up and I’m fixing to start tuning the timing curve for the mad 6010 to run with ez efi throttle body injection on my gen 3 5.3. Do you have any recommendations or timing cure points that I should try, thanks a lot
