Any carb guys running E85?
Fuel ran good. Didn't run it enough, and got sick of cleaning the carb. Went back to race fuel.
I am running it. The benefits are great but maintence is annoying. Ive had a few issues pretty much only due to running the E85 for performance you cant beat it if your not able to run race gas.
Tried the Lucas. Didn't do anything to stop the gelling. If your car sits for more that a couple days. It will gel in the float bowls. Just be diligent about cleaning the bowls and metering blocks and you will be fine. We cleaned ours at the end of every outing, just to be sure. Once it gels, it will eventually get into the circuits and lean your tune out. You won't believe the corrosion that occurs and how fast. We ended up not spraying with it. Was too worried about gelling in the fuel solenoids, and leaning them out. Never had any gel in fuel tank or filters. Just the carb. Not sure why. Also you will get a black gooey stuff inside your intake, all the way to the heads that surely can't be good. Not trying to scare you off. Just want you to understand the maintenance that is involved with E85. Hopefully you will at least check periodically so you don't burn your motor up like a few friends of mine did from not checking. Best of Luck.
that's interesting, I know about 6 guys who run it also but all are FI. Never heard of it gelling, but they probably drive theirs more often. I know they all said to check the fuel blends when I buy it. Now I know a gallon in my standalone would sit for a while.
Been running it for about 8 months with a Pro Systems carb and no problems. The car sits for a couple of weeks or more before I refill since it's not my DD.
I have a procedure for shutting it down if I don't plan to drive it for a week or more.
Pull one screw from each float bowl and drain, refill with regular gas through the vent tube with a syringe bottle. I put a cap on the fuel tank vent to prevent humidity and I store the car with at least 3/4 tank of fuel.
My shop is in Florida, not air conditioned, hot and humid and so far no problems. Because it's difficult to get I always keep about 20 gallons on hand in plastic race fuel jugs and the Lucas additive, no problems gelling.
I know several guys that run it with EFI as well. They all went back to Race fuel. Injecters are expensive. The problem is when it sits. If it's a daily you won't see it. You will see what I mean. I didn't say this stuff to try to start any type of argument. I just wanted you to be aware of what I found. I hope everything works out good for you. Its just been my and about twenty other guys experience. Best of Luck.
well I guess I'll see the results. I did check a shop that specializes in E85 today and he told me that maybe the blend is off is why it's gelling. He checks the blend every time at the shop. he keeps 55 gallon drums of it. He also said that sometimes you get a 70 blend which maybe could gel?? he said. I'll keep an eye on it.
The take away here is E85 certainly is not easy or as trouble free as race fuel, I don't think anyone would argue that but with the proper system design and some maintenance precautions and a reliable fuel source it can be very successful. You just have to weigh the inconveniences vs. the benefits and decide if it is right for you.
It is more difficult to maintain with a carb setup due to the increased exposure to humid air though the carb vents and I will be soon changing to EFI using E85 compatible injectors and other carefully select parts.
But the main reason for going EFI is to get better control of the fuel curve. Not knocking the carb but my car is very dual purpose , it was built for Drag Week type events and I want to be able to optimize both the street and race tunes.
