Holley intake manifold won't seal
The groove in the intake is very small (3/32 in), much smaller of a groove than a regular LS manifold that uses the rubber seals. and it will only accept that particular 0-ring which is included when you buy the manifold.
The Edelbrock intake had a history of cracking when cut to accept GM o rings, so they must have tried to solve it by making a smaller groove.
Mine cracked orig, I contacted them, but they never responded, so I welded them up. GM o rings are expensive, but I had the orange ones (Felpro?) tend to kind of melt on me.
I just used gaskets and no problems after that.
If you have the one that uses the small black O-rings as opposed to the factory seals I would definitely check. Spray brake fluid at all the intake runners where they meet the head. If it does leak, I used the felpro 1312-3 paper gaskets and now It seals just fine.
Casting defect ? Not to add insult to injury but this is why I bought an edelbrock intake instead of an overseas holley . I've read about situations like yours . Best of luck hope you get it figured out .
I just received my new Holley LS3 and looks a lot better then my old one, same style just newer. I had the Puck installed so didn't want down time. I don't see hardly any casting flash like my older one, it's a lot smoother inside and now they milled a small angle on top of the port for clearance. I had to use a small grinder/file to do the old one as it hit the top lip of the cylinder head. Plus I bought it to clear my stock hood, the Edelbrock would not.
But to be safe I did use the felpro gasket 1222-2
The supplied O-rings work fine. Used them in our Procharged LS2 with a Mid-Rise EFI intake (dual quad style lower) at 12psi.
The problem is you milled the heads .015" and didn't have the intake angle milled to match. Therefore you created enough of a total variance to achieve the leaks.
I will agree that Holley had some casting issues out of the box with their early releases, I spent 2+ days porting and shaping my Mid-Rise intake to create even CSAs in each runner.
Yeah, .015 is nothing. I took the manifold to my machine shop and they verified it was slightly warped. I put a felpro 1312 paper gasket on it and it seals good. Plus, I believe the EFI manifolds use a different gasket. At least the EFI one I have on the shelf in my garage does, but it might be an old style.
