5.3L, 243 heads 228r Cam Input.....
Thoughts on my setup..........
2004 5.3L stock rotating assembly
Double roller timing chain
243 Heads milled -.024
Texas Speed 228r .600/.600 108 LSA
Matching springs and push rods
780 holley 4150
Muncie M-20 4 speed w/3:42 gears.
1972 Camaro (3600 lbs. Car)
780 holley 4150
The carb is big I know but I had it from my last build and works good. Double roller is cheap insurance I wouldn't have it any other way. This engine is in and running just looking for some constructive feedback on what others have done.
LS1Tech Premium Sponsor
Ok. from doing carb builds too, id say take some time with the timing box and make a few shakedowns if you can. i assume youve got the msd or equivalent and a laptop of course.
Ive seen em take 26 to 30 degrees, but the best thing about em is its not stuck there.
Itll be a fun setup and honestly 6600 to 6800 might be where it should shift. The single planes and smaller cid hold power way better in the upper rpms than the larger cid and reg long runner fuel inj manifolds.
Interesting mix of old and new school. Cam is pretty big and good flowing heads, if the exhaust flows right and you have a single plane like suggested you should be able to use that much carb. Ought to be thumper as well.
I started playing with the timing start 12* ramp to 24* 700 flat through 1100 ramp to 32* 1100-3000 all in. Pulls hard starts good when hot, still playing with it. Any recommendations on timing?
