Bump box with a 6010
Wondering if anyone using a bump box on a MSD 6010. If so, how much timing do you pull when on the box and transbrake. I know it depends on how much boost your building. My understanding is that you don't start pulling timing until around 5-7 pounds. By the way, this is going to be a higher compression (10.8) E85 5.7 engine with a 74mm BW.
Start Line Spark Advance
Hi Rick, I manufacture the IGN-8-LS ignition Controller.
This Ignition System was used by PML when we made the first "carbed" LS-1. (GMPP)
The starting line settings are based on specified Launch RPM. (4000 ?)
The Timing Retard is proportional and a Max Specified Value is stated. (60 ATDC)
That does NOT STOP the engine RPM increase at times, so we ALSO have a Stutter Table.
This creates a "random" miss-fire cutting cylinders in a rotational order.
THUS, all cylinders stay hot and boost is high.
Lance
Lance
