How to run a Carb car off gas can? - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Old 07-10-2018, 03:50 PM
Default How to run a Carb car off gas can?
I'm looking to pick up a 1969 Impala with a 327 in it. The gas tank is currently not on the car but I want to start the car and see how she runs before buying it.
Can I just take some hose, connect it to the intake and return ports on the carb and just dunk the hoses in a jerry can?
fayzee is offline
Old 07-10-2018, 04:05 PM
Return port on a carb??? Just inlet, and you'll need a pump. Don't you know how cars work??
G Atsma is online now
Old 07-10-2018, 04:33 PM
If you can get gas into the float bowls, it can start and run for a short time. (15 seconds, maybe) Use the vent tubes to fill them up, but I guess the problem is that you can overfill them.
Cunning69 is offline
Old 07-10-2018, 05:41 PM
squarles67 is offline
Old 07-10-2018, 07:22 PM
Pop N Wood's Avatar
Ho man that is exactly the video I was thinking of. Don't do that
You need some way to pressurize the carb. Either a fuel pump or get the source high to gravity feed (like a lawn mower)
If you just want to check for knocks and such just fill the bowls through the vent using a syringe or squirt bottle of some sort. I once drove a car home a half block at a time that way.
Pop N Wood is offline
Old 07-10-2018, 08:34 PM
Doug G's Avatar
Fill the carb bowls with fuel
Connect a hose from gas can to the rear (inlet side) of fuel pump
Crank to start
Once its running, it should pull fuel from gas can
Good to go
Doug G is offline
Quick Reply: How to run a Carb car off gas can?
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
