Sticking Carb Gasket Fix !
Moroso Buna N gaskets are vastly superior to even the blue gaskets.
Cooking spray helps as well. Especially on the paper ones.
https://www.jegs.com/p/Moroso/Moroso...43753/10002/-1
I will try the moroso ones thanks
Hey guys I have been trying a few different things to stop ripping carb gaskets.
What do you use to make them last longer?
https://youtu.be/YsWjDoDQoEs
I remember you could do ANYTHING on a Holley while mounted. Jet changes especially.
Maybe guys are changing out whole carbs for a different setup..
On my old combo SBC with a HEI, rear bowl was always a pain at the track doing jet swaps. LOTS more room now without the HEI.
But not looking for every .001 any more.
I may swap jets once in a while, but now I just plug in the laptop, make a timing change or three IF I fell the need.
Yeah I can see where HEI would get in the way of that back bowl. Enough to make you switch to a Carter... NOT!! lol
