6.0 with ls3 head build??
All in how far you want to go.
JUST WATCH YOUR PTV CLEARANCE USING A LQ4/LS3 COMBO !!!!
The following users liked this post:
camarozz383 (09-10-2020)
Why LS3 heads on a 4.00 bore? Unless your intended power range is going to be 7k plus I would look into the 225 Trickflows instead, especially if its going to be a street car. You will have enough flow, less valve shrouding and higher air speeds with the 225s for street use. Camshaft depends on Compression ratio - Head specifications and desired power band range. Call Circle D for converter recommendations
damn! Was that a sbe 6.0? Can you share some info on that build??
Its stock bottom end. The only thing non stock I guess is the rod bolts and the notches in the pistons for the custom Ed Curtis cam.. The heads have cleaned up ports and have been milled extensively. It runs Pump gas and has a vic jr, 2 inch carb spacer, 950 pro systems carb, turbo 350, 5500 BTE 8 inch converter, 4.30 gears. That 5.93 was in June. It was fairly hot and humid. Hoping when the cool fall air gets here, we MIGHT see some 5.8s. Actually hoping if we keep the front end close to the ground, we might squeak out a 5.79999. I don't know if it can do that, but you can bet, Ill be trying. In this mid 80-90 degree air it usually goes 6.02-6.04, so some good 30 degree cooler air should free up some power.
2-step and higher RPM ???
I launch off foot brake at about 3000. If I leave harder, its generally faster, but hard to hold at the line. Im really hoping I can pull out a 1.19 60 before the years end. My old motor(last 6.2) went 1.23, I think the best Ive gotten out of this one so far is a 1.24-5? But Im sure I can get better, just a fine line between keeping front end down and rear tires hooked.
We here at Livernois Motorsports offer a great selection of cnc ported cylinder heads and camshafts to match the application.
For your set up I would do a set of our pro series heads and the stage II-c hi lift camshaft with a 3400-3600 stall this would give you a great powerplant with excellent street manners and longevity.
https://www.livernoismotorsports.com/product/LPP761104
https://www.livernoismotorsports.com/product/LPP801121
Give me a call or pm me.
313-561-5500 ext 122
Scott
Scott
