Notices
Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Should I worry ???
Old 12-17-2018, 06:45 PM
Doug G's Avatar
Default Should I worry ???
Been looking at maybe adding a turbo one day and in my searches/reading I found where one guy said it's easy to tell when a piston goes because it will blow out the dip stick and spray oil everywhere.
This did happen to me, but the car still runs great and shows no issues. I'm thinking I going to borrow a bore scope.
Doug G is offline
Old 12-17-2018, 07:01 PM
Worn rings will do that too. Anything that spikes crankcase pressure will do as you describe.
G Atsma is offline
Old 12-17-2018, 08:00 PM
Doug G's Avatar
Well, it was a fresh build.... and had less than 500 miles too.
Think I might still take a look when I get a chance.
Doug G is offline
Old 12-17-2018, 10:45 PM
Amazon had wifi/Bluetooth bore scopes for $20. Really nice for the money, much better than my harbor freight scope.
tug686spd is offline
Old 12-18-2018, 03:53 PM
Doug G's Avatar
Link ?
Doug G is offline
Old 12-18-2018, 03:56 PM
Kfxguy's Avatar
If you don’t have enough crankcase evacuation vs the boost your running, that will happen. Or so I’m told. I have two 3/8” bent hoses on mine and haven’t been over 10psi yet and all is good with mine so far.
Kfxguy is online now
Old 12-19-2018, 03:32 AM
TTur1996's Avatar
Since it was a fresh build there is a possibility that the rings weren't fully seated at the time. Does or did your catch can fill with oil? If not I think your fine. Try a compression test first and if that doesn't show anything( which it should ) then do a leak down test. I will bet your fine. Lokar makes a nice locking dipstick.
TTur1996 is offline
Old 12-19-2018, 12:23 PM
fast89stang's Avatar
Ive broke 2 of my pistons at the very top, never blew dipstick, but I have crank case evac. One cylinder the last time was down 70 psi cranking compression. Still ran "ok", but was slightly down on power.
fast89stang is offline
Old 12-19-2018, 04:20 PM
Doug G's Avatar
Thanks....I'll be checking soon.
Doug G is offline
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
