Don't know carbs. Need help.
I know this is not a ls. However it's still cool. 69 with dz302 4053 holley. 72 primary 76 secondary. Vacuum reads 12. Power valve 6.5. Idle is 900 rpm. So problem is runs like crap. I can turn idle mixture screws all the way in and it doesn't affect motor at all. I've check float level. And used vacuum on the power valves to make sure they close they close at 5 psi I didn't see the psi drop while holding it there. Anything else I can do? Need help don't know what else to look for.
1) whats your vacuum at idle? the vacuum needs to be higher than the power valve
2) big cam? how much do you have the throttle blades cracked? are you past the tranfer port holes? i'd guess thats your issue
this may help if you havent read it.....
https://www.holley.com/blog/post/hol..._valve_tuning/
https://www.onallcylinders.com/2013/...y-carburetors/
Blown power valve could cause it as well. As could a leaking gasket or blocked air bleed.
Glad you got it fixed! And thanks for reporting back, as it will help others.
