Notices
Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Low End Torque
Old 05-14-2019, 01:09 PM
Jgant813's Avatar
Default Low End Torque
This will be a pretty different thread compared to most. I am kicking around the idea of building an aluminum LS for a direct drive airboat application. Max rpm would be about 3500 rpm.
My thoughts are an L33 or LS2 with around 12.0-12.5 CR with 706 heads, custom ground low end cam, dual plane intake, long tubes, and e85 carb to help with compression. I know 243s have superior flow characteristics, but I thought the added compression and restriction from smaller 706 heads would help with low end torque. Am I wrong?
I know a 4 stroke would be the easiest way to make tons of torque, but Id like to stay away from spending +$2000 on a rotating assembly if at all possible.
Does anyone think you could make 200+ hp and 400-450 ft/lbs at around 3000 rpm with a properly specd cam and some of the mods listed above?
i have also struggled to find any dyno data below 3000 rpms. If anyone has graphs/tables under 3000 Rpm please post/link so I can get a better idea of lower rpm numbers
Jgant813 is offline
Old 05-14-2019, 02:03 PM
Pop N Wood's Avatar
Sounds like the same problem aircraft people are trying to solve
http://www.epi-eng.com/aircraft_engi...te_engines.htm
Expensive displacement unfortunately
Pop N Wood is offline
Old 05-14-2019, 03:46 PM
Jgant813's Avatar
Thanks for the link. At least gave me a better idea of somewhat lower rpm numbers.
Unfortunately, you are probably right. The few direct drives I have heard of on airboats have all been 427s.
The LS2 in stock trim is a little better than I imagined however. You dont think their would be significant gains down low with roughly a 2 point increase in compression and 706s? Especially with a cam and dual plane designed for this specific purpose?
All this is is just theoretical at this point anyways. I was just figuring a 0320 4 cyl lycoming makes roughly 160 hp and 311 ft/lbs at 2700 rpms weighing about 270 lbs and can go just about anywhere you want to with 2 people and a cooler on a properly set up boat.
I think if you can hit over 200hp + 400 ft/lbs at 3000-3500 it would be pretty similar performance wise only weighing less than 100 lbs more
Jgant813 is offline
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
