Assistance Appreciated - 1996/1997 SS Research
Restricted User
I'd appreciate some assistant if you don't mind on the 1996/1997 Camaro SS :-)
I'm researching information on 1996 & 1997 Camaro SS's and while the Z28 for both years had:
(Std) M6 - 3:42 gears
(opt) A4 - 2.73 gears
(opt) A4 - 3.23 gears (w/ GU5)
I have seen the following for 1996 & 1997 SS's :
A4 - 3.23 (w/ GU5)
M6 - 3.42
However have not been able to locate ANY 1996's nor 1997 SS's with a factory :
A4 - 2.73
or any other factory combination.
Am I then correct to assume that the 1996 & 1997 SS option only had :
A4 - 3.23 (w/ GU5)
M6 - 3.42
and that if the 1996/1997 Z28 was optioned with SS when it had the A4 - 2.73 that it would be changed to an A4 - 3.23 (w/ GU5) ?
Much appreciated,
Paul
A4 - 3.23 (w/ GU5)
M6 - 3.42
A4 - 2.73
A4 - 3.23 (w/ GU5)
M6 - 3.42
Much appreciated,
Paul
