Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
02 camaro top speed problem
Old 01-08-2010, 11:20 AM
MOZART9T's Avatar
Default 02 camaro top speed problem
hi
I have a 2002 camaro Z28 A4 with 2.73
yesterday I was trying to get more than 150 mph, it was on D so it should shift to fourth but it didn't , top speed was more than 150 and 6000rpm
at third than it was like braking or cutting the power at that speed
does it have a speed limiter?
I heard it will not shift to fourth at that speed to protect the transmission ?
my car is full bolt ons cam and a tune
Old 01-08-2010, 12:13 PM
eseibel67's Avatar
I believe there is a speed limiter on the factory tune based on speed rating of tires.
Custom tune should be able to adujst it.
But don't drive that fast. Please.
Old 01-08-2010, 07:00 PM
cure07's Avatar
if its in D and not overdrive it will only be using 3 gears not 4 and the speedlimiter is 155 if you have 245 tires
Old 01-08-2010, 07:03 PM
puggerton03's Avatar
where are you trying to go faster then 150 at?
Old 01-08-2010, 07:21 PM
blk/slvr02ss's Avatar
They are limited to 162 but i don't know if they are w/2:73's.
Old 01-09-2010, 05:05 AM
MOZART9T's Avatar
it's in overdrive gear, so it should shift to fourth
that's why I have 2.73 to go as fast as my car can go
Old 01-09-2010, 01:35 PM
meine96ws6's Avatar
i agree with the shift and 160+
Old 01-09-2010, 04:08 PM
Moderator
davered00ss's Avatar
Yes, you have a limiter in your car if you have the stock tune
Quick Reply: 02 camaro top speed problem
