Just bought wheels and need some input
hey everyone i just got 2006 zo6 wheels and they are (2) 17x9.5 and (2) 18x10.5 and i was wondering if the rear rims will fit and if 245/40/17 in the front and 275/35/18 in the rear would be a good fit... thanks in advance for all advice.
Wheel Fitments
The numbers in the columns are as follows:
WIDTH ..... OFFSET ......... WIDTH OF TIRE
Front and Rear
7.0" ..... +35 to +40 mm .... 215, 225, 235
7.5" ..... +35 to +45 mm .... 215, 225, 235
8.0" ..... +38 to +55 mm .... 225, 235, 245
8.5" ..... +38 to +45 mm .... 235, 245, 255
9.0" ..... +38 to +56 mm .... 255, 265, 275
9.5" ..... +38 to +56 mm .... 255, 265, 275, 285
10.0" ... +38 to +48 mm .... 265, 275, 285
REAR Only
10.0" ... +38 to +54 mm .... 275, 285, 295
10.5" ... +38 to +50 mm .... 285, 295, 305, 315
11.0" ... +45 to +56 mm .... 305, 315, 335
NOTE: 315 series tires DO NOT fit 9" or 9.5" wheels. It will not be discussed any thread posting will be edited, locked or deleted.
source: https://ls1tech.com/forums/wheels-ti...must-read.html
Front and Rear
REAR Only
Z06 Corvette Replicas:
17"x9.5" +50 to +56 mm no problems. 275/40R17.
18"x9.5" +50 to +56 mm 275/35R18 or 285/35R18.
18"x10.5" +50 to +53 mm. Higher than 53 mm will require the BFH mod. 285/35R18s thru 315/30R18. Over 295 may require rolling the fenderlip and will need the BFH. +58 mm is the typical available offset for the Z06 replica, which will require a little BFH and/or a small spacer.
