What were the exact changes in 01 ?
I know i read about the clutch hydraulics etc and the ls6 intake but can anyone tell me what I would need to do to upgrade?
What parts exactly in the clutch system are changed? Master and slave?? Are the clutches the same?
If i drop on an ls6 intake manifold do I just need block off plates? Will it pop codes?
'if' The one car I have my heart set on comes home I'll be doing longtubes in it without egr anyways so i understand I can just tune the codes out for that. Does the 98-00 benifit from an ls6 intake?
Location: Your girl's back door giving her the long stroke while you're at work
The 01-02 cars came with the LS6 clutch. The 01-02 cars also came factory with the LS6 intake
https://ls1tech.com/forums/1740881-post3.html
Cool link. I feel like passing on a 99 ss now lol. I was sure the clutch master or slave was revised as well?
From what I remember, the 01 cam is smaller but the intake helps it make more power. I am guesing an ls6 on a 98-00 will net a pony or 2 more if I put it on?
If I do get a 98-00 I will definitely do the ls6 and ls7 clutch and newer clutch hydraulics. then I'll feel better.
It's not mine! woo hoo!
I also wouldn't worry about the clutch at all. When it comes time to replace it, then just upgrade the hydraulics rather than doing the clutch and upgrade before it's shot.
