Oil for Tremec tko600?
This is the info that came with my TKO 500
Oil
Caution: NO OIL IN TRANSMISSION. Due to various synchronizer materials used in TREMEC
transmissions, and different climates and applications, no one single fluid will work for all transmissions. We
recommend GM synchromesh part # 12345349, or Dexron III / Mercon Spec ATF fluid for all TKO
transmissions. The transmission should be filled through the fill plug located on the passenger side of the
transmission. Proper fill level is achieved when oil reaches the fill plughole when level (approximately 5.28
pints)
Clutch housing
Oil
pints)
Clutch housing
