turn signal not working
I have a 1999 chevy camaro z28. The problem im having is the front driver side turn signal stays on instead of flashing. The rear turn signal flashes fine as do both on the right side. All work fine when the flasher is pushed. Ive replaced the light socket, the bulb, and the flasher for the blinkers, and still the same. Also the light on the dash for the turn signal does not work for the drivers side but you can hear the flasher clicking. Any suggestions?
My front turn signals on my WS6 did that a while back, it was due to moisture getting into the light socket and rusting. Replaced the bulb and light socket and occasionally spray silicon around the edge of the housing and havn't had a problem since. If you have already replaced the bulb and light socket and it still won't work, it may just be a wiring problem. Other than that I don't know what else could be causing that.
