Story and build of my $300 Thirdgen
#41
Thanks for the pos feedback guys. Bought the knock sensor harness and sealed it with rtv I was told it was a cheap insurance seeing as how moisture can get in and cause the sensors to fail other than that just trying to survive the cold weather need to fix the sag in my pass side door. Have been lurking on here for the past few hours and seen some nice cars really adds to the motivation that im getting closer to being done hope to have it running by june for americruise even if I have no ac/heat and rocking the primer
#43
I was wroonggg oh so much this drivers pillar is a pain in the a** forgot that the dash is short and leaves a gap which offsets the pillars from each other the only that is making it a little easier is the use of the gauge pod heres the general mock up of it
#44
Space heater I had burned itself out not that it really worked, anyways onward harness came in today it needs reloomed also bought a pedal assem, hvac controls, and bezel for the gauges still working on the a pillar need to get a steering column next
#45
Alright most of the harness ive gotten figured out courtesy lights are wired in full time, taillights turn signals sidemarkers gauges all light up. Need to change over the plugs for the headlights other than that the main wiring is pretty much done
#46
Nice work!
Hoping to start my 3rd gen LS-1/T-56 build soon. How difficult was it to fit the 4th gen harness to the 3rd gen body? Did you have to lengthen anything? I'm not sure if you mentioned if you were going auto or t-56? I have all the big stuff but there are lots of little things to buy other then the ls-1/t-56 and various harnesses. I too am going with the 4th gen interior. Big question, do you have to smog it? I live in cali and its a big hassle here.
#47
Going t56. I did not have to lengthen any of the wires but make sure you get a Camaro harness(unless you have a t/a) wiring will be easier to understand you'll have to splice the tail light harness into the 4th gen harness. And luckily no I don't have to smog it so goodbye cats, rear o2's, evap, egr.
Got the headlight plugs spliced in figured out why my brake lights weren't working routed the wiring where it all needs to be waiting on pedal assem to show up then looking at getting a steering column. Got rid of the blue LEDs under the dash put white ones in otherwise not much has changed
#48
Little bit of advice for anybody doing this swap into a thirdgen the top holes where the booster goes through the pedal assem, the holes need drilled out larger i didnt know this and apparently nobody has had this problem and its just my f***ing luck or they thought it just wasnt important, thought it was just the angle i was trying to put it in nope had to pull the assem back out and drill them also the wiring harness has to routed after the master and booster are bolted in spent two hours fighting with it but its in need to run the wires for the line lock decided im going to get the hvac system now rather than later when the dash is wired in making twice the amount of work also buying a clutch master and fuel rails thats all for now
#50
Pics pics and more pics
Cleaned both the garages
Box of goodies- tr55 plugs, new o2s, new iac/tps, new alt, new dayco belts.
Oh and my 1320 sticker
Very happy with how the interior came out and shiny everything is minus the primer lol
#52
Alright update first the harness I bought was wrong was from a 98 corvette so sold it and bought another harness from a 99 camaro also bought a amp seems and looks new got it extremely cheap.
#53
Bit of progress got the stereo system wiring finished up really need new speakers the ones I had laying around are blown.... Got the rear hatch wired up got the ecu mounted where I want it and will be tucked out of the way best as possible. Also got my seats put back in I think that's all for now
#55
Update and some news........
First buddy I work with had a flip out he gave me which is awesome its pretty basic but has dvd, usb mp3 port, bluetooth, sub output so works for me need to fix the rubber stripping on the screen heres pics
Secondly... found out wife is pregnant so project will be set back hopefully not the back burner but progress will probably slow
#56
Really been almost a whole month with no update weathers been crap and works been crazy working at both autozones without a day off but little bit of an update got some founders spherical double adj lca's for $20 less than 500 miles, got all new locks for the doors and hatch. Other than that been gathering parts for the motor, suspension, brakes will run the stock 3rd gen rear and brakes till after I get it running then will do the brake and rear upgrade to a 4th gen setup
#58
So plan is as follows motor is out of the car and finally have a day off with nice weather so want to clean polish the heads put the car in the air clean and undercoat the trans tunnel after that head to Upullit to see if I can find a hvac box if not will be rebuilding the front steering/suspension and cutting the front coils car has set for quite some time with the motor in place and it's horribly high oh and headlights should be here today as well don't know that I'll do anything with them till I get all the other stuff I need for them will update tomorrow with pics
Also anybody have the part number for the tool to remove the crank pulley??
#59
So............ changing plans going auto so now for sale the pedal assem and a brand new clutch master simply doing this for cost and reliability also have almost everything I need to rebuild the front steering/brakes/suspension also got the motor adapters(wrong ones) so monday i have to go get the right ones. Believe thats all for now
