Question about 4th gen LS1 alternator wire routing
Can anyone tell me how the factory routed the 4th gen Ls1 alternator power / charging wire to the battery?
The biggest question is how it was routed from the alternator, did it clamp from underneath between the front of the oil pan and behind the harmonic balancer? Or did it travel a different path?
The battery is on the passenger side on these cars aren't they?
Thanks in advance
Thanks in advance
awesome, thanks again. Right now the wire is coming off the lug for the starter (same one that battery is hooked too) and running tightly to the oil pan under the motor to the alternator.
I did a LS swap in my 71 and trying to duplicate how it would have been factory. I didn't get that harness and I'm **** about those little details lol
awesome, that's exactly what I needed to see. I have a 4th gen elec fan assembly in my 71 so the routing will be perfect.
Does that power wire for the alternator run through a fuse? Or just supplying power to the fusebox?
Thanks again for the help
so the red wire from the alternator goes in the red cover ?
