hydraulic or solid valve lifters???
I bought a car. guy doesn't know anything about the car but he had a bunch of work done by a shop and I have an itemized list/ receipt of what they did but its not very detailed. I contacted the shop and they cant give info cause im not original customer. its an ls1 in a 98 Camaro light years from factory so I dont need to know what the factory releases.
some info on the sheet says
:ls1 custom grind 235/240 .643"/ .609" 111 lsa +1
how do I find out if I have hydraulic or solid valve lifters?
thanks in advance
thanks in advance
That's just the cam specs. You can't tell from that if the lifters are hydraulic or solid.
It's quite likely that they're hydraulic roller lifters, but I believe you'd have to visually inspect them to be certain.
