L59 swap into 95 camaro fuel issue
I have been trying to get ready to swap an l59 out of my 02 suburban into my 1995 camaro. I've have been able to get everything figured out, my motor mounts, wiring harness, belt drive, and oil pan. Everything except my fuel supply I dont know what pump i can use. Id like to use an in the tank if possible. Hopefully some body could help me.
Was your car a V6 or Lt1 V8 originally? You could upgrade to the Walboro 255 if a V6 or V8, but the V8 Lt1 pump should handle it fine. I have a 93 Z28 that I swapped a Lq4 in and my factory LT1 pump is doing fine. I plan on upgrading to the Walboro 255 gph as I am about to do heads and cam.
