69 Camaro with 454 and th350 trans
Just moved my buddy's 69 down to my shop to pull the trans and do a rebuild on it. My question for you guys is since he has replaced the old 328 (I think that was the stock engine) with a 454, will I still be able to get the tranny out without removing the engine. There doesn't appear to be much room between the block and the firewall to get to the upper bolts. I haven't torn into it yet but, I am hoping that after I remove the breather and more than likely the distributor, there will be enough room to get to the bolts. Anyone know? Or have suggestion?
