98 camaro turn singal issues
My 98 z28 Camaro front passenger turn signal is not flashing. Even with hazards on. Drl comes on but won't flash. I've replaced both flasher relays all new bulbs and sockets and cannot find the problem. Guy who had car before me had led bulbs in it and they were both solid now for some reason.Every turn signal work even passenger rear works as it should expect for passenger front. PLEASE HELP
I just had a similar problem in a rear turn signal on a 2000 Grand Prix. Previous owner had wired the third brake light into the regular brake light wire instead of fixing it right, and it shorted when the brake was pressed when the signal was on. I would suggest tracking the wires, maybe the PO wired something like HALO's in or something at one time and used the wrong wire.
Ok i checked the wires for power on the drl box:
-With left turn signal activated my voltmeter flashes when testing the light blue/white striped wire while the power at dark blue is continuous.
-With right turn signal activated my voltmeter flashes when testing the dark blue wire while the power at light blue/striped wire is NOT on at all.
Help....
Help....
