Drl/turn signal issue I've noticed that the drl/turn signal light isn't working on the passenger side. The 194 bulb not the 3157. The bulb itself looks fine and i put it on the other side and it does work. Not sure if a wiring issue or bad socket |
1 Attachment(s) What's the condition of the socket? Does it look like it's been hot? I would then check for power at the socket first. |
Check if the socket has corrosion in it, if so you need to replace the socket itself. Easy enough job but they aren't cheap, I know because I had to replace 3 out of the 4 light sockets in my front end. Also, before you connect the wires, test them in the new socket. My passenger side has a ground issue in the harness, so I ran a new ground wire to the frame until I'm ready to pull the front harness out and check the wires individually. |
© 2024 MH Sub I, LLC dba Internet Brands
