Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Abs inop light and no cruise control when I use headlight switch
Old 08-21-2017, 04:16 PM
Nick Lally's Avatar
Default Abs inop light and no cruise control when I use headlight switch
I just bought this 95 camaro z28 and I knew it had problems and all when I bought it but I can't seem to figure out why my cruise control doesn't work when I have my headlights or running lights turned on. I could be using cruise control just fine and then as soon as I turn the switch on it'll cut out and the abs inop light will turn on. I think it has something to due with the fact that the high mounted brake light on the spoiler doesn't work for some reason or the fact that the previous owner put in aftermarket led tail lights, or maybe both. There's a greenish grayish wire that comes from the high mounted brake light to somewhere in the front of the car. Does anyone know where that wire leads or any other solutions to this problem? Ps: all fuses are fine I checked.
Quick Reply: Abs inop light and no cruise control when I use headlight switch
