2002 z/28
2002 z/28
So I recently bought a Black 2002 Z/28 while I was in Japan from back in the states. I have some of the basic info of the car, and I had a question. The insurance company ran the VIN of my car, and they said it was a 2002 Z28/SS. I am having trouble finding out exactly what that means is different about the car. It doesn't have any of the SS external options that I've seen, it is just a stock Camaro that had the RS ground effects package. So can someone help identify exactly what is different about my car? Pictures and VIN below.
VIN: 2G1FP22G322146530
LS1Tech Administrator
Received 1,486 Likes
Nothing about the VIN number tells you specifically if the car is a Z28 or SS, only that it's a V8 Camaro. So your insurance company must be grouping the two together if they are not specifically asking you which one it is.
What you have pictured above is clearly a Z28 model with the SAP (Sport Appearance Package, RPO Y3F on your SPID sticker) and not an SS model (an SS would contain RPO WU8). In fact, the SAP was not even available on SS models from the factory (Y3F not available with WU8).
So I've been looking online, and I actually found one or two articles concerning Camaros referred to as Z28/SS, stated as having been a model from mid 2001 to mid 2002. At the risk of sounding stupid, why would the vins get lumped together like that from the insurance agency? It even says that on the insurance card. I'm stuck in between right now, because as I previously stated I havnt seen this before and after what you said, I started to believe it more. But I seem to be finding stuff that says otherwise online and having insurance (I know they don't know **** besides the VIN but still) back it up only makes me want to figure this out 100% even more.
My 99
My 1999 Camaro Z28 is the same it has it on the title as Z28 SS I was told because there made in house there titled the same and what options from slp would be in your rpo codes this started when they started the slp stuff in house
Your car is 100% a base Z28, not an SS. All SS camaros had the hood scoop, ss wing and 17x9" wheels.
For what its worth it doesn't matter as the SS models really did not make any more power and was more of an appearance package than anything else unless they got the better option suspension bits.
Here is your build sheet, not a SS from what I can see.
ehicle Build
Model: 1FP87-2002 CAMARO 2 DR COUPE Order Number: A71121
Gross Vehicle Weight: 1,915 Build Date: 03/25/2002
Build Plant: 2
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
19B - EBONY
19I - INTERIOR TRIM EBONY
1SA - PREFERRED EQUIPMENT GROUP - 1SA
41Q - MOLDING COLOR-BLACK
41U - BLACK 6BS -
7BS - 8TJ -
9TJ - AG1 - 6-WAY POWER DRIVER SEAT
AK5 - RESTRAINT SYSTEM - AIR BAG, DRIVER AND PASSENGER SIDE
AR9 - RECLINING FRONT BUCKET SEATS
B84 - BODY SIDE MOULDINGS
BBS - HURST SHIFTER
C49 - REAR WINDOW DEFROSTER
C60 - AIR CONDITIONING
CC1 - REMOVABLE ROOF PANELS
D35 - MIRRORS - DUAL OUTSIDE SPORT
DE4 - REMOVABLE SUNSHADES DT2 -
FE2 - FIRM RIDE & HANDLING SUSPENSION
FE9 - FEDERAL CERTIFICATION EMISSION
G80 - DIFFERENTIAL - LIMITED SLIP
GU6 - 3.42 AXLE RATIO
IPB - TRIM INTERIOR J65 - BRAKES - FOUR WHEEL DISC
K05 - HEATER - ENGINE BLOCK
K43 - GENERATOR 102 AMP
LS1 - 5.7L SFI V8, 310 HP
MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - 6-SPEED MANUAL TRANSMISSION
NF7 - FEDERAL EMISSION SYSTEM
NK3 - SPORT STEERING WHEEL LEATHER
PW7 - POLISHED ALUMINIUM WHEELS 16X8"
QFZ - ALL SEASON PERFORMANCE BLACKWALL TIRES, P245/50Z X 16 SLM -
STE -
T82 - TWILIGHT SENTINEL
U19 - KILO SPEEDOMETER
U73 - FIXED RADIO ANTENNA
UB3 - GAUGE CLUSTER WITH TACHOMETER
UN0 - RADIO - AM/FM ST. W/ CD PLAYER
UZ7 - MONSOON 8 SPEAKER SYSTEM WITH 500 WATT PEAK POWER
V12 - POWER STEERING COOLING, HVY DTY
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
VK3 - LICENSE PLATE BRACKET
WT4 -
Y3F - SPORT APPEARANCE PACKAGE * SPECIAL "GROUND EFFECTS" * FRONT/REAR LOWER FASCIA * EXTENSIONS & ROCKER PANELS WITH AGGRESSIVE THREE PIECE REAR DECK LID SPOILER
Z28 - CAMARO Z28
Z31 - PRELIMINARY INVOICE
Z49 - CANADIAN BASE EQUIPMENT
ehicle Build
Build Plant: 2
Option Codes
19B - EBONY
41U - BLACK 6BS -
7BS - 8TJ -
BBS - HURST SHIFTER
STE -
WT4 -
Z28 - CAMARO Z28
Ship to Information
Ship to Service Agent: 120404
SENTES CHEVROLET LTD.
933 WESTMINSTER AVENUE W.
PENTICTON BC V2A 1L1 2504932333 Ship to Date: N/A
Sold by
Delivery Service Agent: 120384
SMITH CHEVROLET CADILLAC LTD.
950 NOTRE DAME DRIVE
KAMLOOPS BC V2C 6B9 2503722551 . Delivery Date: 05/30/2002
Delivery Type: 015---RETAIL LEASE - INDIVIDUAL
Delivery Odometer: 100
Sold by
