Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Shark Gray 2000 SS build
Old 12-09-2019, 09:22 AM
  #301
LaBLKv6Z's Avatar
LS1Tech 10 Year
Originally Posted by CoreyD
Looking good! Excited to see the results
Thanks man, forsure.
Old 12-09-2019, 10:50 AM
  #302
AINT SKEERED's Avatar
New cam is pretty wild. Look forward to seeing it run
Old 12-09-2019, 03:47 PM
  #303
Rabo73's Avatar
Oh man,,,you're in DEEP!!!! I can't take it anymore,,, I'm getting nauseous!
Old 12-09-2019, 03:50 PM
  #304
Rabo73's Avatar
Thumbs up
Seriously, way beyond my skill set. Good for you and everyone else willing to go the distance!
The following users liked this post:
LaBLKv6Z (06-16-2021)
Old 12-11-2019, 09:32 AM
  #305
"I MAID THEESE"
Mavn's Avatar
Why the ls7 stage 4 cam on a 427 with ls3 heads ?
Old 12-11-2019, 10:21 AM
  #306
00pooterSS's Avatar
That cam will have a hair less duration too with the 1.7 rockers
I don't know where a calculator is to figure out exactly what it will come out to though.
Old 12-11-2019, 10:47 AM
  #307
LaBLKv6Z's Avatar
LS1Tech 10 Year
Yeah, I decided to go with an off the shelf* max effort type camshaft and curious to see how it will do in my 4.07" bore setup.
Old 12-11-2019, 11:05 AM
  #308
00pooterSS's Avatar
When you factor in the 1.7 ratio that cam becomes very very similar to the cam you took out. If you were wanting to go considerably bigger you may want to pause on installing that cam and run the numbers.
Old 12-11-2019, 11:26 AM
  #309
LaBLKv6Z's Avatar
LS1Tech 10 Year
The two cams are similar, I wanted more duration and lift. Even with the rocker ratio factor decrease from the cam card, the intake and exhaust duration is increased quite a bit from the cam I was running.
Old 12-11-2019, 01:58 PM
  #310
00pooterSS's Avatar
Even factoring in slightly less duration from the 1.7 rockers?
Old 12-11-2019, 02:58 PM
  #311
LaBLKv6Z's Avatar
LS1Tech 10 Year
Correct, I've had this cam on my shelf for about 6 months btw. Finally got around to installing it the other night lol.
00pooterSS (12-11-2019)
Old 12-16-2019, 11:39 AM
  #312
LaBLKv6Z's Avatar
LS1Tech 10 Year
Measured and ordered new push rods. I'm needing 7.550" long push rods for .035" preload on my Johnson reduced travel race lifters. Went with 3/8".
Also started disassembling the suspension off of the kmember. Plan to drop the kmember from the engine next.
AINT SKEERED (12-16-2019)
Old 12-16-2019, 03:33 PM
  #313
I'm using 3/8" trickflow pushroda. Worked great with my 823 heads
Old 12-16-2019, 04:42 PM
  #314
LaBLKv6Z's Avatar
LS1Tech 10 Year
Cool deal, yeah I researched to see if there were any issues running 3/8" rods in LS3 heads, seemed all good.
Old 12-17-2019, 06:37 AM
  #315
raymond mckinney's Avatar
LS1Tech 10 Year
Nice build. Love the stage's.
Old 12-22-2019, 09:07 AM
  #316
Bigbirdtrucker's Avatar
Love the car great pics
Old 12-25-2019, 03:42 PM
  #317
lsujerry's Avatar
Very nice build , I just moved to Pine Prarie, from Thibodaux a year ago or so. When you get a chance can you shoot me some info on car meets in the Lafayette area.
Thanks, Happy Holidays !!
Old 12-26-2019, 06:55 AM
  #318
LaBLKv6Z's Avatar
LS1Tech 10 Year
Thanks guys,
For local meets check out, Lafayette Louisiana Car Cruise news, Acadiana Gear heads, Humpday cruise nights, on FB.
Old 01-03-2020, 03:53 PM
  #319
LaBLKv6Z's Avatar
LS1Tech 10 Year
ARP hardware lubricated and torqued.
Push rods going in.
Rocker arms torqued down.
Old 01-03-2020, 03:56 PM
  #320
LaBLKv6Z's Avatar
LS1Tech 10 Year
Had to modify the passenger side LS1 valve cover.
Injectors and rail installed.
Quick Reply: Shark Gray 2000 SS build
