Shark Gray 2000 SS build
#124
Just went through the whole thread. What got me interested was your 31mph back half. Beautiful car & awesome build. Gives me encouragement to give my car some TLC.
I see you're looking into a vacuum pump. Not many street cars have them. I went with the GZ setup. I really like having a vacuum pump. Having a vacuum gauge connected to the opposite valve cove, from where the pump is connected, is really cool. As being able to see what the pump is doing/vacuum or what the crankcase is getting. Before the gauge I was just guessing what it was doing.
Again. Awesome car man!
#125
Thanks guys.
Thanks man, it definitely feels stronger compared to the last setup.
The GZ kits are really nice and looks like a quality pump. I am looking into using 2 electric air pumps, in line with each other. Should be good for 8 lbs. I know its not much but may possibly help.
#129
Love the pics with the Judge dude!!!!!
#131
I’m happy with how the car performed. DA was in the negative but it was cold all day. Track condition was okay. First run I dropped the clutch from 3k and bogged it. Second run I dropped the clutch from 3.5k and got some wheel hop. Third run I left off of the two step set at 4.3k, softly engaging the clutch. Still had some wheel hop in second but pulled off my best et.
#133
Moved my wideband gauge from the ash tray in the console to the radio location this weekend. I'll be installing Speed Inc light weight carpet and deleting the console. I found it much easier to row through the gears without the center console.
#139
So the stock power steering pump started leaking all over the new engine. I decided to pull it off and run the shorter belt for now. Steering is a bit tougher with the smaller steering wheel.
