95 lt1 crank no start
I have a 95 lt1 camaro cranks no start has spark at plugs fuel pressure at 40 psi also power to injectors and injectors are pulsing was driving down road at55 car kinda stumbled and nackfired out exhaust babied it home tried giving gas but bogged down once home it was ideling and then just died and wont start any ideas guys?
Have you checked for any codes set or possibly a plugged fuel filter or return line? Otherwise, you may need to look at the fuel pump. I've attached pages from 95 service manual that may help you troubleshoot.
The service manual says if you have "less than 41 PSI of fuel pressure it may cause a lean condition and set DTC 44/64. Drivability conditions can include hard starting cold, hesitation, poor drivability, lack of power, surging and backfiring.
