3rd Brake Light not working
99 Camaro Z28 3rd brake light not working replaced the bulbs and nothing and my rear defroster isn’t working I’ve replaced the breaker and it get annoying because i can’t see in the mornings
Ungrounded Moderator
The common element between the third brake light and the rear defogger is that they are both in the hatch and connected through the same wiring harness. Chances are that the wires are broken but you could check that the connector isn't loose or damaged first. The connector has two pins with a yellow and a purple wire located at the rear of the roof near the dome light. If the connector is okay then you'll probably have to start tracing the wires from there to the hatch to find where they're broken.
