Aeroquip AQP high pressure hose for PS
I'm using the AQP -06 AN high pressure hose for power steering high side. I have the steel AN -06 reusable fittings that are supposed to work with AQP hose, but it seems like the hose is actually slightly larger diameter(even with the top edge of the nut) than the nut it's supposed to slide in to. Everything is AN-06....I don't get it. Is there a trick??
They make re-usable fittings for that hose. Call your local hose house. I don't have the numbers here. Also, don't confuse the teflon hose fittings for the regular ones like you posted, they are not interchangeable.
