04 GTO wiring harness.... Need confirmation this looks correct.
Hi everyone! I'm a newbie here and need a little help. I am using an 04 GTO engine/ harness/ pcm on my BMW M3 LS1 swap. Unfortunately I havent been able to find a specific writeup on using the GTO harness. I found the pinout for an F-body (99 Camaro) and compared it to the GTO, they are very similar. It looks like there are 12 wires that need to be used from an F-body harness. Comparing the pin locations at the PCM on the GTO harness, I found they are in the same locations. The main difference I found was the GTO has a few more ground wires. The comparison is made at the PCM because the GTO doesnt have the same # of connectors on the body side of the harness. The pinout (for the GTO) goes like this:
C1 Connector
#1- Ground
#19- Ign voltage (switched 12v)
#20- Batty voltage (constant 12v)
#24- Ground
#27- Ground
#40- Ground
#57- Batty voltage (constant 12V)
#58- OBDII for DLC connector
#64- Ground
#67- Ground
C2 connector
#1- Ground
#9- Fuel pump (relay trigger)
#10- Tach signal (output to gauge)
#33- Cooling fan (relay trigger)
#40- Ground
#46- Ck eng (ground side of SES circuit)
Does this look like I have accounted for all wires that need to be connected to make the engine start and run? Thanks in advance for the help!
C1 Connector
#1- Ground
#24- Ground
#27- Ground
#40- Ground
#64- Ground
#67- Ground
C2 connector
#1- Ground
#40- Ground
Pm me a fax # and I could send you the print out,or for $25 you can get a ALLDATA account for the year good for one car,and it has all the GTO info you'll need. Good Luck
C1 Connector
#1- Ground ok
#19- Ign voltage (switched 12v) "
#20- Batty voltage (constant 12v) "
#24- Ground "
#27- Ground "
#40- Ground "
#57- Batty voltage (constant 12V) "
#58- OBDII for DLC connector "
#64- Ground "
#67- Ground "
C2 connector
#1- Ground ok
#9- Fuel pump (relay trigger) "
#10- Tach signal (output to gauge) "
#33- Cooling fan (relay trigger) "
#40- Ground "
#46- Ck eng (ground side of SES circuit) "
C1 Connector
#1- Ground ok
#24- Ground "
#27- Ground "
#40- Ground "
#64- Ground "
#67- Ground "
C2 connector
#1- Ground ok
#40- Ground "
Powertrain Control Module Connector End Views 04 gto
Table 1: PCM Connector C1
Table 2: PCM Connector C2
Connector Part Information
• PCM Connector C1 92231110
• 80-Way Micro-Pack 100W Series Sealed (BU)
Pin
Wire Color
Circuit No.
Function
1
BK/RD
450
Ground
2
L-BU/WH
2867
12-Volt Reference - CKP Sensor
3
PU
1746
Fuel Injector 3 Control
4
GN
1745
Fuel Injector 2 Control
5-6
Not Used
7
BU/YE
596
5-Volt Reference - EOP Sensor
8
GY
2701
5-Volt Reference - TP Sensor
9-10
Not Used
11
L-BU
1876
KS 2 Signal
12
L-BU
573
CKP Sensor Signal
13-16
Not Used
17
YE
1225
Transmission Fluid Pressure Switch Signal B
18
GY
1226
Transmission Fluid Pressure Switch Signal C
19
OG
300
Ignition 3 Voltage
20
OG
740
Battery Positive Voltage
21
L-BU/BK
574
Low Reference - CKP Sensor
22
Not Used
23
BK
2759
Low Reference - FTP Sensor and Fuel Level Sensor
24
BK/RD
450
Ground
25
TN
1671
HO2S Low Signal Bank 2 Sensor 2
26
GY/BK
1667
HO2S Low Signal Bank 2 Sensor 1
27
BK/RD
450
Ground
28
TN/WH
1669
HO2S Low Signal Bank 1 Sensor 2
29
BU/BK
1664
HO2S Low Signal Bank 1 Sensor 1
30
GN
68
Engine Coolant Level Signal
31
Not Used
32
BU/WH
771
Transmission Range Switch Signal A
33
BN
86
Cruise Control Release Signal
34
WH
776
Transmission Range Switch Signal P
35
Not Used
36
BU
1744
Fuel Injector 1 Control
37
YE
846
Fuel Injector 6 Control
38-39
Not Used
40
BK/RD
450
Ground
41-42
Not Used
43
PK/BK
877
Fuel Injector 7 Control
44
BN/YE
844
Fuel Injector 4 Control
45
PU/WH
2700
5-Volt Reference - A/C Refrigerant Pressure Sensor
46
GY
2709
5-Volt Reference - FTP Sensor
47
Not Used
48
PU/WH
2704
5-Volt Reference - MAP Sensor
49-50
Not Used
51
BU
496
KS 1 Signal
52
Not Used
53
BK/WH
2762
Low Reference - TFT Sensor
54
BK
469
Low Reference - MAP Sensor
55-56
Not Used
57
OG
740
58
YE
1045
RFA Class 2 Serial Data
59
Not Used
60
BK/YE
2752
Low Reference - TP Sensor
61
RD/WH
632
Low Reference - CMP Sensor
62
Not Used
63
GN
470
Low Reference - EOP Sensor
64
BK/RD
450
Ground
65
PU/BK
1670
HO2S High Signal Bank 2 Sensor 2
66
GY
1666
HO2S High Signal Bank 2 Sensor 1
67
BK/RD
450
Ground
68
PU/WH
1668
HO2S High Signal Bank 1 Sensor 2
69
PU
1665
HO2S High Signal Bank 1 Sensor 1
70-71
Not Used
72
YE/RD
772
Transmission Range Switch Signal B
73
BN
633
Camshaft Position Signal
74
YE
410
ECT Sensor Signal
75
Not Used
76
GY
845
Fuel Injector 5 Control
77
L-GN
878
Fuel Injector 8 Control
78
Not Used
79
GN/WH or GY
898 or 587
Shift Solenoid Valve 3 High Control - Skip/Shift Solenoid Control
80
GY/BK
2761
Low Reference - ECT Sensor
PCM Connector C2
• PCM Connector C2 92231110
• 80-Way Micro-Pack 100W Series Sealed (GN)
Pin
Wire Color
Circuit No.
Function
1
BK/RD
450
Ground
2
BN
418
TCC PWM Solenoid Valve Control
3-5
Not Used
6
RD
1228
PC Solenoid Valve High Control Sol.A
7
Not Used
8
GY/BU
1229
PC Solenoid Valve Low Control Sol.A
9
GN/WH
465
Fuel Pump Relay Control Primary
10
BN
121
Engine Speed Signal - Tachometer
11
Not Used
12
GY/BK
1687
Ignition Retard Signal, from EBCM
13
Not Used
14
GN/BK
380
A/C Refrigerant Pressure Sensor Signal
15-17
Not Used
18
GN
59
A/C Compressor Clutch Supply Voltage
19
Not Used
20
TN
1231
AT ISS Low Signal
21
BU/WH
1230
AT ISS High Signal
22-23
Not Used
24
BU
411
TP Sensor Signal
25
BN
472
IAT Sensor Signal
26
WH
2121
IC 1 Control
27
YE
2127
IC 7 Control
28
L-GN
2126
IC 6 Control
29
WH
2124
IC 4 Control
30
Not Used
31
BN/WH
492
MAF Sensor Signal
32
L-GN
432
MAP Sensor Signal
33
BU/WH
473
High Speed Cooling Fan Relay Control
34
GN/YE
428
EVAP Canister Purge Solenoid Control
35-38
Not Used
39
WH/BK
631
12-Volt Reference - CMP Sensor
40
BK/RD
450
Ground
41
Not Used
42
GY/RD
422
TCC Solenoid Valve Control
43
L-GN/BK
459
A/C Clutch Relay Control
44
YE
1652
Reverse Lock Out Solenoid Control
45
WH
1310
EVAP Canister Vent Solenoid Control
46
BN/WH
419
MIL Control
47
YE/BK
1223
2-3 Shift Solenoid Valve Control
48
L-GN
1222
1-2 Shift Solenoid Valve Control
49
Not Used
50
PU/WH
5197
VSS Signal
51
YE/BK
1227
TFT Sensor Signal
52
L-BU
1150
HO2S Bank 1 Sensor 2 Heater Control
53
RD/WH
1350
HO2S Bank 2 Sensor 2 Heater Control
54
PU
30
Fuel Level Sensor Signal
55-56
Not Used
57
GN/OG
5514
Low Reference - IAT Sensor and A/C Refrigerant Pressure Sensor
58
BN/WH
331
Engine Oil Pressure (EOP) Sensor Signal
59
Not Used
60
BN
2129
Low Reference - Ignition Coils Bank 1
61
PU
2130
Low Reference - Ignition Coils Bank 2
62
GY
773
Transmission Range Switch Signal C
63
BN/YE
1224
Transmission Fluid Pressure Switch Signal A
64
D-GN
890
Fuel Tank Pressure (FTP) Sensor Signal
65
Not Used
66
L-BU
2128
IC 8 Control
67
YE/BK
2122
IC 2 Control
68
GN
2125
IC 5 Control
69
BU
2123
IC 3 Control
70-71
Not Used
72
BK/WH
1050
HO2S Bank 1 Sensor 1 Heater Control
73
Not Used
74
L-GN/RD
1250
HO2S Bank 2 Sensor 1 Heater Control
75
Not Used
76
L-GN/WH
1749
IAC Coil B High Control
77
L-GN/BK
444
IAC Coil B Low Control
78
L-BU/BK
1748
IAC Coil A Low Control
79
L-BU
1747
IAC Coil A High Control
80
Not Used
hope this helps
Pin
Wire Color
Circuit No.
Function
1
BK/RD
450
Ground
2
L-BU/WH
2867
3
PU
1746
4
GN
1745
5-6
Not Used
7
BU/YE
596
8
GY
2701
9-10
Not Used
11
L-BU
1876
KS 2 Signal
12
L-BU
573
CKP Sensor Signal
13-16
Not Used
17
YE
1225
18
GY
1226
19
OG
300
Ignition 3 Voltage
20
OG
740
21
L-BU/BK
574
22
Not Used
23
BK
2759
24
BK/RD
450
Ground
25
TN
1671
26
GY/BK
1667
27
BK/RD
450
Ground
28
TN/WH
1669
29
BU/BK
1664
30
GN
68
31
Not Used
32
BU/WH
771
33
BN
86
34
WH
776
35
Not Used
36
BU
1744
37
YE
846
38-39
Not Used
40
BK/RD
450
Ground
41-42
Not Used
43
PK/BK
877
44
BN/YE
844
45
PU/WH
2700
46
GY
2709
47
Not Used
48
PU/WH
2704
49-50
Not Used
51
BU
496
KS 1 Signal
52
Not Used
53
BK/WH
2762
54
BK
469
55-56
Not Used
57
OG
740
58
YE
1045
59
Not Used
60
BK/YE
2752
61
RD/WH
632
62
Not Used
63
GN
470
64
BK/RD
450
Ground
65
PU/BK
1670
66
GY
1666
67
BK/RD
450
Ground
68
PU/WH
1668
69
PU
1665
70-71
Not Used
72
YE/RD
772
73
BN
633
74
YE
410
ECT Sensor Signal
75
Not Used
76
GY
845
77
L-GN
878
78
Not Used
79
GN/WH or GY
898 or 587
80
GY/BK
2761
PCM Connector C2
Pin
Wire Color
Circuit No.
Function
1
BK/RD
450
Ground
2
BN
418
3-5
Not Used
6
RD
1228
7
Not Used
8
GY/BU
1229
9
GN/WH
465
10
BN
121
11
Not Used
12
GY/BK
1687
13
Not Used
14
GN/BK
380
15-17
Not Used
18
GN
59
19
Not Used
20
TN
1231
AT ISS Low Signal
21
BU/WH
1230
AT ISS High Signal
22-23
Not Used
24
BU
411
TP Sensor Signal
25
BN
472
IAT Sensor Signal
26
WH
2121
IC 1 Control
27
YE
2127
IC 7 Control
28
L-GN
2126
IC 6 Control
29
WH
2124
IC 4 Control
30
Not Used
31
BN/WH
492
MAF Sensor Signal
32
L-GN
432
MAP Sensor Signal
33
BU/WH
473
34
GN/YE
428
35-38
Not Used
39
WH/BK
631
40
BK/RD
450
Ground
41
Not Used
42
GY/RD
422
43
L-GN/BK
459
44
YE
1652
45
WH
1310
46
BN/WH
419
MIL Control
47
YE/BK
1223
48
L-GN
1222
49
Not Used
50
PU/WH
5197
VSS Signal
51
YE/BK
1227
TFT Sensor Signal
52
L-BU
1150
53
RD/WH
1350
54
PU
30
55-56
Not Used
57
GN/OG
5514
58
BN/WH
331
59
Not Used
60
BN
2129
61
PU
2130
62
GY
773
63
BN/YE
1224
64
D-GN
890
65
Not Used
66
L-BU
2128
IC 8 Control
67
YE/BK
2122
IC 2 Control
68
GN
2125
IC 5 Control
69
BU
2123
IC 3 Control
70-71
Not Used
72
BK/WH
1050
73
Not Used
74
L-GN/RD
1250
75
Not Used
76
L-GN/WH
1749
77
L-GN/BK
444
78
L-BU/BK
1748
79
L-BU
1747
80
Not Used
hope this helps
