is the 98 engine harness different?
I am not sure about the dash plug. Are you planning on putting in a camaro cluster into a 240? Or wiring the 240 gauges into the lsx computer?
The 1998 harness is different when it comes to the engien harness and you will need to use a 1998 computer.
The plugs on the engine are the same with the exception of the temp sensor. The plugs for the PCM are different alltogether and the body plugs are pinned different as well as having a few wires they do not share.
Re'
Re'
