LS1 in 69 Camaro, Stock Speedo and tach???
I'm putting in a LS1 into my 69 Camaro and want to keep the interior stock. There is a kit for the LS1 to work with the stock 1969 Speedo but does anyone if there is a kit or some way I can keep the stock tach??? Thanks
i don't own a dakota digital unit, but from what i've read, their unit causes the speedo to jump around a lot during quick acceleration. i was considering swapping the guts of my original speedo w/ the guts of a cheepo digital unit off ebay. should be able to program pcm to calibrate guts w/ numbers on faceplate.
anybody happen to know the pulse count for the F_body tachometers??? the ECM tach output should be a pulse count for the stepper motor tachometer in the instrument cluster. in older units, the tach pulse factor was stored in the EEPROM.
Needs to finish car
The tach signal comes from the crank sensor, and LS1 tachs run in 4 cyl mode, typically. The earlier motors have 24 tooth reluctor wheels and 24/6=4, so you need to change it to 3 to get 24/3=8.
My LS7 has a 58 tooth wheel, so there's no simple solution since these numbers have to be integers, but making one number 8 and the other 7 made the tach right on the money for me.
