Mustang swap ?
You will have to drill about a 3/4" hole beside lower rest pad on the passenger side. This will be clearance for an alignment boss sticking out of the radiator. Other than that, it bolts right up like a stock fox radiator. I have no pics of the hole , but once you get a radiator you will know what I'm talking about.
i used stock 99 camaro radiator and fans
i didnt have to drill any holes or anything and used stock f body radiator hoses..... no cutting required
doesnt get much easier than that
why did you guys swap to the f body radiator over the fox? did you have cooling problem?
It came with my motor and trans. The F-body fans mount directly to the radiator. Very nice set-up.
What years/cars are these in? I will need a setup in my F150 for the lq9. Are the electric fans stock too?
How are you all wiring in your fans? Through the pcm? Or a switch in the car?
