Help identify a DBW Throttle body ????
I'm installing a late 8.1 in a 69 Vette and am currently trying to round up the most appropriate harness and parts (it runs of a LS1 24x crank like an LS1).
The problem is, I'm not sure which other vehicle shares the throttle body on my engine.
It is not the Vette style. I need to know if the one I have is the same as the 2001-2002 ish 5.3 and 6.0 truck dbw tb.
Here is what I have...
You figure that is the same as a 2000-2002 model then?
If so...looks like I can use this LS1 harness to run the motor:
http://www.painlessperformance.com/w...rchField=60219
Based on that...I figure I would need not only that computer noted...but also the pedal and TAC that would fit a 2002 Silverado.
Sound right?
Sound right?
