Corvette Fuel Filter, Russell fitting 640940
Does anyone have a picture of the russell fitting 640940.
I think its what I need for my corvette fuel filter.
I'm trying to make the output side go directly to an AN fitting.
I can't find a picture of this fitting anywhere.
That part number is for a zinc fitting, do you want the red and blue maybe/
See link...
http://www.russellperformance.com/mc...fit/fuel.shtml
See link...
For the output side of the VETTE FPR.. you would need to use a short peice of 3/8" tubing with the correct QD barb on it, Doman sells a short peice or find a short donner peice. Then you would need a Compression to AN adapter for the 3/8" tube.
Chech the FAQ.. as it should how many have used the Vette FPR and adapters to AN fittings.
You can use the 640930 and 640940 on the inlet and return ports.
See the link, page 6 post # 106, it's the second picture, that one is 5/16" I believe, but the 3/8" looks just like this.....
https://ls1tech.com/forums/conversio...ap-faqs-6.html
T,
vette fpr with all 3 russell AN fittings (in/out/return). here's a link to russell's 2009 catalog. see lower right corner, there's a picture of it. and here's a better picture courtesy of pirate4x4.
So that is the fitting i'll need.
Thanks alot.
