PCM mounting brackets... what are you guys using?
Old 09-04-2009, 01:24 PM
RYU
RYU's Avatar
Default PCM mounting brackets... what are you guys using?
I'm planning to mount my PCM on the passenger fender of my 66 A-body.
What are you folks using for mounting brackets?
Old 09-04-2009, 03:13 PM
pist0lpete's Avatar
I mounted mine where the glovebox used to be. I used some strap aluminum and mounted it vertical. I lost the glovebox in the process though.
Old 09-04-2009, 03:37 PM
cutlass_455's Avatar
I used plumbers strapping with foam sticky tape stuck to it. It hasnt seen the real world yet, but see how it goes.
Old 09-04-2009, 07:50 PM
clm69z28's Avatar
For my 72 Chevelle, I used the factory plastic PCM bracket/harness and mounted it to a piece of aluminum, which I then attached to the cowling underneath the drivers side fender. Nice and weatherproof and it saved me the hassle of going through the firewall with the connectors etc. With the plastic innerfender, it is fairly easy to get to and it looks very clean.
I remember a thread not too long ago that included a lot of pics of different solutions that guys had come up with. See if you can find it.
Old 09-04-2009, 10:02 PM
john 67's Avatar
I just mounted mine on the inside firewall above the center console using an aluminum plate and some angle to support it from the upper cowl instead of drilling through the firewall to mount it.look on the last page of my thread to see it. JOHN
Quick Reply: PCM mounting brackets... what are you guys using?
