TAC trouble
Old 09-14-2009, 01:21 PM
garretthes's Avatar
Default TAC trouble
After driving the truck for a year I'm suddenly having this problem. Intermittent stalling and engine being sent into reduced power mode.
Here are the trouble codes.
P1516 Throttle Actuator Control (TAC) module actuator position performance
P2135 Generic throttle pos sens/switch a/b correlation
I checked with my scan tool to see if the accelerator was providing accurate info to the TAC. All I have is the tps abslte %. It seemed to provide smooth increase in percentage all the way to wot. The problem is it reached wot at about half pedal.
Now I'm wondering if I have the correct TAC module. The engine has never run 100% since the install.
Old 09-15-2009, 02:07 PM
garretthes's Avatar
Has anyone else ever checked their accelerator to see if the position % was smooth according to the TPS? Concerned that mone reaches 100% at half throttle.
Old 10-30-2009, 10:29 AM
garretthes's Avatar
After screwing the TAC module to the inner fender my problem is solved. THis could simply mean the module needs to be grounded.
